library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
use IEEE.std_logic_unsigned.all;
library UNISIM;
use UNISIM.vcomponents.all;
entity g1_applic_top_vhdl is
GENERIC (
Hotlink_SDMA_Base : integer := 0; -- Define the first SDMA engine used by HOTLINK instance 0.
used_engine_mask : std_logic_vector(31 downto 0):= shift_left(X"0000FFFF", Hotlink_SDMA_Base) OR '0'; -- Set 16 bits = 8 Hotlink ports * 2 engines
used_wbus_chan_mask : std_logic_vector(25 downto 0):= shift_left("00000000001111111111111111", Hotlink_SDMA_Base) OR '0' -- Set 16 bits = 8 Hotlink ports * 2 wbus_chans
PORT ();
