Problem in wireless transmition Using 89S52.
tapu
Full Member level 4
india
Dear All,
I am transmitting decimal number 0 to 99 wireless by using ''RF seriel uart data link''.both side 89s52 used.code written in keil IDE.As module property data recieve for one second and then stops for one second then recieve for one second this process continues.Therefore my output display ON and OFF continously.My problem is Here how to stable output data on display?My code is given below. please reply.
Tramsmitting code:
#include <REGX52.H>
sbit e1=P1^7;
sbit e3=P2^1;
sbit e0=P2^0;
sbit e2=P2^2;
sbit e4=P2^3;
sbit buz=P1^7;
sbit sw=P2^4;
sbit sw1=P2^5;
sbit sw2=P2^6;
sbit sw3=P1^3;
//sbit rinc=P3^3;
//sbit rdec=P3^2;
//sbit rset=P3^1;
bit ring=0;
bit a;
//#define off P2=0x00
unsigned int min;
unsigned char dat;
unsigned char message;
	 void display();
  void loop();
void Seg8_decimal2(min);
Send2lcd(unsigned char value);
 void delay_ms(unsigned int ms_count);
   void delay_us(unsigned int us_count);
 unsigned char pt,pt1,pt2,pt3,span;
//unsigned char num[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void main()
	min=00;
		SCON=0x50;
    TMOD=0x20;
		TH1=253;
    TR1=1;
	TMOD |= 0X20;                       // Timer 1 in mode 2
	TH1=0xFD;                            // Baud rate of 1200
	SCON = 0X50;                         //Asynchronous 8-bit data
	TR1 = 1;                             // Turn ON the timer
	while(1)
	if(ring==1)
		SBUF=message;
		ring=0;
		SBUF =min;
	while(TI==0);
	TI=0;
 loop();
		if(a==1)
		span++;
    buz=0;
	delay_ms(10);
    buz=1;
		if(span==70)
a=0;
	buz=1;
			span=0;
  void loop()
		//delay_ms(100);
		 Send2lcd(min);
 Seg8_decimal2(min);
		//if(sw==0)
		//rinc=0;
		//else
			//rinc=1;
		//if(sw1==0)
		//rset=0;
		//else
		//rset=1;
		//if(sw2==0)
		//rdec=0;
		//else
			//rdec=1;
	pt=1;
while(!sw)
	if(pt==1)
min++;
ring=1;
SBUF=255;
	pt=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	//delay_ms(10);
	a=1;
while(!sw1)
//while(sw==0);
	if(pt==1)
min--;
		pt=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	//delay_ms(10);
	if(min==0xffff)
		min=999;
while(!sw2)
	if(pt==1)
min=0;
	pt=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	//delay_ms(10);
	a=1;
while(!sw3)
	if(pt==1)
min=0;
	pt=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	//delay_ms(10);
	a=1;
	//rinc=1;
unsigned int Lcd_hr,Lcd_t,Lcd_o;
Lcd_hr=min%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
dat=Lcd_t+0x30;
		display();
	//P1=0x04;
	e3=1;
	delay_ms(5);
	e0=e2=e3=0;
dat=Lcd_o+0x30;
		display();
//P1=0x08;
	e2=1;
delay_ms(5);
		e0=e2=e3=0;
if(min>99)
	if(min<=199)
P0=0xf9;
	//P0=0xf9;
e0=1;
delay_ms(5);
		e0=e1=e2=e3=0;
if(min>199)
	if(min<=299)
P0=0xa4;
	//P0=0xf9;
e0=1;
delay_ms(5);
		e0=e1=e2=e3=0;
if(min>299)
	if(min<=399)
P0=0xb0;
	//P0=0xf9;
e0=1;
delay_ms(5);
		e0=e1=e2=e3=0;
if(min>399)
	if(min<=499)
P0=0x99;
	//P0=0xf9;
e0=1;
delay_ms(5);
		e0=e1=e2=e3=0;
if(min>499)
	if(min<=599)
P0=0x92;
	//P0=0xf9;
e0=1;
delay_ms(5);
		e0=e1=e2=e3=0;
if(min>599)
	if(min<=699)
P0=0x82;
	//P0=0xf9;
e0=1;
delay_ms(5);
		e0=e1=e2=e3=0;
if(min>699)
	if(min<=799)
P0=0xf8;
	//P0=0xf9;
e0=1;
delay_ms(5);
		e0=e1=e2=e3=0;
if(min>799)
	if(min<=899)
P0=0x80;
	//P0=0xf9;
e0=1;
delay_ms(5);
		e0=e1=e2=e3=0;
if(min>899)
	if(min<=999)
P0=0x90;
	//P0=0xf9;
e0=1;
delay_ms(5);
		e0=e1=e2=e3=0;
if(min>999)
min=00;
unsigned char buf1,buf2,buf = 0;
buf1 = value & 0xF0; /* Filter for high byte */
buf1 = (buf1>>4); /* Convert to ascii code */
buf2 = value & 0x0F; /* Filter for low byte */
buf=(buf1*10)+buf2;
return buf;
        while(ms_count!=0)
            delay_us(112);   //delay_us is called to generate 1ms delay
             ms_count--;
    while(us_count!=0)
         us_count--;
	 void display()
		 if(dat==0x30)
		P0=0xc0;
		//P0=0x3f;
		 if(dat==0x31)
		P0=0xf9;
		//P0=0x06;
		 if(dat==0x32)
		P0=0xa4;
		//P0=0x5b;
		 if(dat==0x33)
		P0=0xb0;
		//P0=0x4f;
		 if(dat==0x34)
		P0=0x99;
		// P0=0x66;
		 if(dat==0x35)
		P0=0x92;
		//P0=0x6d;
		 if(dat==0x36)
		P0=0x82;
		//P0=0x7d;
		 if(dat==0x37)
		P0=0xf8;
		//P0=0x07;
		 if(dat==0x38)
		P0=0x80;
		//P0=0x7f;
		 if(dat==0x39)
		P0=0x90;
		//P0=0x6f;
Recieving code:
#include <REGX52.H>
sbit e1=P2^1;
sbit e2=P2^2;
sbit e3=P2^3;
sbit buz=P1^7;
sbit on=P3^7;
sbit sw3=P1^0;
sbit sw2=P1^1;
sbit sw1=P1^2;
sbit sw=P1^3;
sbit zero=P0^0;
sbit one=P0^1;
sbit two=P0^2;
sbit three=P0^3;
sbit four=P0^4;
sbit five=P0^5;
sbit six=P0^6;
sbit seven=P0^7;
//sbit eight=P0^8;
//sbit nine=P0^9;
sbit SDA=P2^6;
sbit SCL=P2^7;
bit a;
#define off P2=0x00
#define EEPROM_ID 0xa0
unsigned int min;
unsigned char dat;
void EEPROM_WriteByte(unsigned char eeprom_Address, unsigned char eeprom_Data);
unsigned char EEPROM_ReadByte(unsigned char eeprom_Address);
void I2C_Start();
void I2C_Stop(void);
void I2C_Ack();
void I2C_Write(unsigned char dat);
unsigned char I2C_Read();
void I2C_NoAck();
void I2C_Clock();
unsigned char ansdigi1;
unsigned char ansdigi2;
unsigned char ansdigi3;
unsigned char push=00;
unsigned char lt=0;
	 void display();
  void loop();
	unsigned char catch;
void main()
	buz=0;
	pt1=0;
	P1=0xff;
	P2=0x00;
	  SCON=0x50;
    TMOD=0x20;
		TH1=253;
    TR1=1;
	min=00;
	while(1)
	while(RI==0);
	min=SBUF;
			Send2lcd(min);
 Seg8_decimal2(min);
	RI=0;
	lt=0;
 //loop();
	// min=EEPROM_ReadByte(0x01);
	// EEPROM_WriteByte(0x01, min);
  void loop()
			//P0=ansdigi1;
		//delay_ms(100);
		 Send2lcd(min);
 Seg8_decimal2(min);
	pt=1;
while(!sw)
	pt1++;
	if(pt==1)
		if(push==0)
		if(lt==0)
min=1;
push++;
			lt=1;
		if(push==1)
			if(lt==0)
			min=min*10+1;
			push++;
			lt=1;
				if(push==2)
					if(lt==0)
			min=min*10+1;
			push=0;
					lt=1;
	pt=0;
		buz=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	delay_ms(10);
	a=1;
	if(pt1==100)
		buz=1;
    pt1=0;
			sw1=1;
while(!sw2)
	if(pt==1)
min=min+111;
	pt=0;
	//buz=1;
	 Send2lcd(min);
 Seg8_decimal2(min);
	delay_ms(10);
	if(min==0xffff)
		min=999;
	 Send2lcd(min);
 Seg8_decimal2(min);
while(!sw3)
	if(pt==1)
min=00;
	pt=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	//delay_ms(10);
	a=1;
while(!sw1)
	if(pt==1)
		if(push==0)
			if(lt==0)
min=2;
			push++;
			lt=1;
				if(push==1)
			if(lt==0)
min=min*10+2;
			push++;
			lt=1;
						if(push==2)
			if(lt==0)
min=min*10+2;
			push++;
			lt=1;
	pt=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	//delay_ms(10);
	a=1;
	buz=1;
Lcd_hr=min%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
dat=Lcd_t+0x30;
		display();
//P0=P3;
	ansdigi2=P0;
	//P1=0x04;
	//P2=0x08;
e3=1;
e2=0;
e1=0;
	delay_ms(5);
	e1=e2=e3=0;
dat=Lcd_o+0x30;
		display();
	ansdigi3=P0;
//P0=P3;
//P1=0x08;
	//P2=0x04;
	e2=1;
	e3=0;
	e1=0;
delay_ms(5);
e1=e2=e3=0;
if(min>99)
	if(min<=199)
P0=0x06;
	ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>199)
	if(min<=299)
P0=0x5b;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>299)
	if(min<=399)
P0=0x4f;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>399)
	if(min<=499)
P0=0x66;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>499)
	if(min<=599)
P0=0x6d;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>599)
	if(min<=699)
P0=0x7d;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>699)
	if(min<=799)
P0=0x07;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>799)
	if(min<=899)
P0=0x7f;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>899)
	if(min<=999)
P0=0x6f;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>999)
min=00;
buf=(buf1*10)+buf2;
return buf;
        while(ms_count!=0)
             ms_count--;
    while(us_count!=0)
         us_count--;
	 void display()
		 if(dat==0x30)
		//P3=0xc0;
		P0=0x3f;
		 if(dat==0x31)
		//P3=0xf9;
		P0=0x06;
		 if(dat==0x32)
		//P3=0xa4;
		P0=0x5b;
		 if(dat==0x33)
		//P3=0xb0;
		P0=0x4f;
		 if(dat==0x34)
		//P3=0x99;
		 P0=0x66;
		 if(dat==0x35)
		//P3=0x92;
		P0=0x6d;
		 if(dat==0x36)
		//P3=0x82;
		P0=0x7d;
		 if(dat==0x37)
		//P3=0xf8;
		P0=0x07;
		 if(dat==0x38)
		//P3=0x80;
		P0=0x7f;
		 if(dat==0x39)
		//P3=0x90;
		P0=0x6f;
    I2C_Start();               // Start i2c communication
    I2C_Write(EEPROM_ID);      // connect to AT2404 by sending its ID on I2c Bus
    I2C_Ack();
    I2C_Write(eeprom_Address); // Select the Specified EEPROM address of AT2404
    I2C_Ack();
    I2C_Write(eeprom_Data);    // Write the data at specified address
    I2C_Ack();
    I2C_Stop();                // Stop i2c communication after Writing the data
    delay_ms(5);            // Write operation takes max 5ms, refer At2404 datasheet
  unsigned char eeprom_Data;
    I2C_Write(EEPROM_ID);      // connect to AT2404(write) by sending its ID on I2c Bus
    I2C_Ack();
    I2C_Ack();
    I2C_Write(0xA1);           // connect to AT2404(read) by sending its ID on I2c Bus
    I2C_Ack();
   eeprom_Data = I2C_Read();  // Read the data from specified address
    I2C_NoAck();
    I2C_Stop();                // Stop i2c communication after Reading the data
    delay_us(10);
  return eeprom_Data;          // Return the Read data
void I2C_Start()
    SCL = 0;        // Pull SCL low
    SDA = 1;        // Pull SDA High
    delay_us(1);
    SCL = 1;        //Pull SCL high
    delay_us(1);
    SDA = 0;        //Now Pull SDA LOW, to generate the Start Condition
    delay_us(1);
    SCL = 0;        //Finally Clear the SCL to complete the cycle
void I2C_Stop(void)
    delay_us(1);
    SDA = 0;            // Pull SDA  low
    delay_us(1);
    SCL = 1;            // Pull SCL High
    delay_us(1);
    SDA = 1;            // Now Pull SDA High, to generate the Stop Condition
void I2C_Ack()
    SDA = 0;        //Pull SDA low to indicate Positive ACK
    I2C_Clock();    //Generate the Clock
    SDA = 1;        // Pull SDA back to High(IDLE state)
void I2C_NoAck()
    SDA = 1;        //Pull SDA high to indicate Negative/NO ACK
   I2C_Clock();     // Generate the Clock
    SCL = 1;        // Set SCL */
    unsigned char i;
    for(i=0;i<8;i++)         // loop 8 times to send 1-byte of data
        SDA = dat & 0x80;    // Send Bit by Bit on SDA line
        I2C_Clock();         // Generate Clock at SCL
        dat = dat<<1;
        SDA = 1;                 // Set SDA at last
unsigned char I2C_Read(void)
    unsigned char i, dat=0x00;
       SDA=1;               //Make SDA as I/P
    for(i=0;i<8;i++)        // loop 8times to read 1-byte of data
       delay_us(1);
        delay_us(1);
        dat = dat<<1;       //dat is Shifted each time and
        dat = dat | SDA;    //ORed with the received bit to pack into byte
        SCL = 0;            // Clear SCL to complete the Clock
   return dat;               // Finally return the received Byte*
 void I2C_Clock(void)
    delay_us(1);
    SCL = 1;        // Wait for Some time and Pull the SCL line High
    delay_us(1);        // Wait for Some time
    SCL = 0;        // Pull back the SCL line low to Generate a clock pulse
I can't even see where the wireless code is in that!
Please add comments so we can at least see what your subroutines actually do.
Brian.
Reciever code with comments.
(here concider while(1) loop)
#include <REGX52.H>
sbit e1=P2^1;
sbit e2=P2^2;
sbit e3=P2^3;
sbit buz=P1^7;
sbit on=P3^7;
sbit ot=P3^6;
sbit sw3=P1^0;
sbit sw2=P1^1;
sbit sw1=P1^2;
sbit sw=P1^3;
sbit zero=P0^0;
sbit one=P0^1;
sbit two=P0^2;
sbit three=P0^3;
sbit four=P0^4;
sbit five=P0^5;
sbit six=P0^6;
sbit seven=P0^7;
//sbit eight=P0^8;
//sbit nine=P0^9;
sbit SDA=P2^6;
sbit SCL=P2^7;
bit a;
#define off P2=0x00
unsigned int min;
unsigned char dat;
void I2C_Start();
void I2C_Ack();
void I2C_NoAck();
void I2C_Clock();
unsigned char lt=0;
	 void display();
  void loop();
void main()
	buz=0;
	pt1=0;
	P1=0xff;
	P2=0x00;
	  SCON=0x50;
    TMOD=0x20;
		TH1=253;
    TR1=1;
	min=00;
	while(1)
	while(RI==0);   //stay on this line till RI=0 (wait to receive)
	min=SBUF;   //read SBUF and store it in min variable
			Send2lcd(min);   //Display-command for 7 segment led display
 Seg8_decimal2(min);   //Display-command for 7 segment led display
	RI=0;   //clear the RI flag
	lt=0;
  void loop()
			//P0=ansdigi1;
		//delay_ms(100);
		 Send2lcd(min);
 Seg8_decimal2(min);
	pt=1;
while(!sw)
	pt1++;
	if(pt==1)
		if(push==0)
		if(lt==0)
min=1;
push++;
			lt=1;
		if(push==1)
			if(lt==0)
			min=min*10+1;
			push++;
			lt=1;
				if(push==2)
					if(lt==0)
			min=min*10+1;
			push=0;
					lt=1;
	pt=0;
		buz=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	delay_ms(10);
	a=1;
	if(pt1==100)
		buz=1;
    pt1=0;
			sw1=1;
while(!sw2)
	if(pt==1)
min=min+111;
	pt=0;
	//buz=1;
	 Send2lcd(min);
 Seg8_decimal2(min);
	delay_ms(10);
	if(min==0xffff)
		min=999;
	 Send2lcd(min);
 Seg8_decimal2(min);
while(!sw3)
	if(pt==1)
min=00;
	pt=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	//delay_ms(10);
	a=1;
while(!sw1)
	if(pt==1)
		if(push==0)
			if(lt==0)
min=2;
			push++;
			lt=1;
				if(push==1)
			if(lt==0)
min=min*10+2;
			push++;
			lt=1;
						if(push==2)
			if(lt==0)
min=min*10+2;
			push++;
			lt=1;
	pt=0;
	 Send2lcd(min);
 Seg8_decimal2(min);
	//delay_ms(10);
	a=1;
	buz=1;
Lcd_hr=min%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
dat=Lcd_t+0x30;
		display();
//P0=P3;
	ansdigi2=P0;
	//P1=0x04;
	//P2=0x08;
e3=1;
e2=0;
e1=0;
	delay_ms(5);
	e1=e2=e3=0;
dat=Lcd_o+0x30;
		display();
	ansdigi3=P0;
//P0=P3;
//P1=0x08;
	//P2=0x04;
	e2=1;
	e3=0;
	e1=0;
delay_ms(5);
e1=e2=e3=0;
if(min>99)
	if(min<=199)
P0=0x06;
	ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>199)
	if(min<=299)
P0=0x5b;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>299)
	if(min<=399)
P0=0x4f;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>399)
	if(min<=499)
P0=0x66;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>499)
	if(min<=599)
P0=0x6d;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>599)
	if(min<=699)
P0=0x7d;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>699)
	if(min<=799)
P0=0x07;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>799)
	if(min<=899)
P0=0x7f;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>899)
	if(min<=999)
P0=0x6f;
ansdigi1=P0;
//P2=0x02;
	e1=1;
	e2=0;
	e3=0;
delay_ms(5);
e1=e2=e3=0;
if(min>999)
min=00;
buf=(buf1*10)+buf2;
return buf;
        while(ms_count!=0)
             ms_count--;
    while(us_count!=0)
         us_count--;
	 void display()
		 if(dat==0x30)
		//P3=0xc0;
		P0=0x3f;
		 if(dat==0x31)
		//P3=0xf9;
		P0=0x06;
		 if(dat==0x32)
		//P3=0xa4;
		P0=0x5b;
		 if(dat==0x33)
		//P3=0xb0;
		P0=0x4f;
		 if(dat==0x34)
		//P3=0x99;
		 P0=0x66;
		 if(dat==0x35)
		//P3=0x92;
		P0=0x6d;
		 if(dat==0x36)
		//P3=0x82;
		P0=0x7d;
		 if(dat==0x37)
		//P3=0xf8;
		P0=0x07;
		 if(dat==0x38)
		//P3=0x80;
		P0=0x7f;
		 if(dat==0x39)
		//P3=0x90;
		P0=0x6f;
    I2C_Ack();
    I2C_Ack();
    I2C_Ack();
    I2C_Ack();
    I2C_Ack();
    I2C_Ack();
    I2C_NoAck();
    delay_us(10);
void I2C_Start()
    delay_us(1);
    delay_us(1);
    delay_us(1);
void I2C_Stop(void)
    delay_us(1);
    delay_us(1);
    delay_us(1);
void I2C_Ack()
void I2C_NoAck()
    unsigned char i;
        dat = dat<<1;
       delay_us(1);
        delay_us(1);
    delay_us(1);
wireless module sends data for one second and off for one second with led blinking.(as its property informed by supplier).But how to stable or store recieved data from SBUF register.please reply.
I still find your code very confusing and I'm not even sure what it is supposed to do.
However, if you are trying to store the received bytes you will have to structure your code differently. At the moment you seem to halt the program until a byte is received, then call "Send2lcd()" which doesn't actually send anything then call "seg8_decimal2()" which I assume is driving an LED, not an LCD. I'm guessing 'e1', e2' and 'e3' are selecting digits somehow but you have not explained what any of the pins are connected to.
You really need to draw a flow chart for this!
To store incoming digits you first have to find some way of telling which digit is which. There is no point in storing everything that arrives if you don't know which order the bytes are in. I suggest you add some kind of marker to the transmitted bytes, something unique that does not appear in normal data that says "the next byte is the first of three" -or- alternatively, a marker that says "the data is now all transferred". You can use the marker byte to prepare your store so it knows the address to store the first, second and third byte and so on.
Next you have to change the main code so it doesn't halt until a byte is received. Instead you want it to run all the time but divert into a routine to save the bytes as they arrive. Change the line "while(RI==0);" to "if(RI==1)..." and save the byte if the test passes. That should help you keep the display stable.
Hint: instead of all those "if(dat==..)" checks, use the num[] array you commented out. You can then remove the 'display()' routine completely and use 'P0 =num[dat]' instead.
Brian.
