dangan1993
Junior Member level 3
Can someone please to help me explain why the DC output is limited by the input power or the DC output get saturated as the input power is high enough? Thank you.
Yes, I concern about a plain voltage doubler loaded with a resistor. In theory, DC output voltage = 2Vpeak. there is no constraint with the peak amplitude of input signal, but I read some papers, Dc voltage is saturated as input power is high. Is it because the non-linear property of diode?Is your question about a plain voltage doubler made from diodes and capacitors? With no load there is a maximum voltage you get at the output. The incoming waveform charges the capacitors to its maximum peak amplitude. There is nothing which discharges them. (Is this what you mean when you say 'saturated'?)
As you add load the capacitors (all of them or some of them) drop to a lesser voltage. It is because the load discharges them somewhat, yet they are not replenished sufficiently during the brief time the incoming waveform exceeds their charge level.
The Farad value of the capacitors has a lot to do with it. Usually by increasing their value, the voltage multiplier can sustain a heavier load.
