kirteshmiet
Member level 1
- Joined
- Feb 16, 2012
- Messages
- 39
- Helped
- 11
- Reputation
- 24
- Reaction score
- 12
- Trophy points
- 1,288
- Activity points
- 1,544
hi in my verilog netlist which has come after synthesis . there is one IO pad instentiate in it . so for this IO pad there are two pins one is PAD and other is C . PAD pin is connected to port and C pin is connected to a net in the design. so how to make connection between PAD and C pin as the signal comming from port has to go in the design through C pin as it is a clock signal.
PISN U_Clk60 (
.C(\U_sBoxRam/udpRam256x8_bist_con/dpRam256x8_bist_dpRam256x8_block_0_instance_0/dpRam256x8_bypass_0_instance_0/bp_clk_12 ),
.PAD(Clk60));
her Clk60 is the port connected to PAD , C is connectd to a net ,PISN is the lef module name taken from IO lef and U_Clk60 is the instance name in the verilog netlist so thell me how to make a connection between C and PAD pins of IO PAD.
thanks
kitty...:-D
PISN U_Clk60 (
.PAD(Clk60));
thanks
kitty...:-D
