problem in using generate statement in verilog
Mkanimozhi
Full Member level 4
Hi ,
i m getting error message when i use generate statement in verilog , i have attached the file with this thread, how to solve this index out range error, what is this meaning,
ERROR:Xst:868 - "sea_top.v" line 116: Index out of range for key_r.
ERROR:Xst:868 - "sea_top.v" line 116: Index out of range for key_l.
ERROR:Xst:868 - "sea_top.v" line 116: Index out of range for fmuxl_out.
ERROR:Xst:868 - "sea_top.v" line 132: Index out of range for key_l.
ERROR:Xst:868 - "sea_top.v" line 132: Index out of range for key_r.
ERROR:Xst:868 - "sea_top.v" line 132: Index out of range for fmuxr_out.
ERROR:Xst:868 - "sea_top.v" line 148: Index out of range for key_r_mux.
ERROR:Xst:868 - "sea_top.v" line 148: Index out of range for key_l_mux.
ERROR:Xst:868 - "sea_top.v" line 148: Index out of range for gn_key.
ERROR:Xst:868 - "sea_top.v" line 68: Index out of range for key_l_mux.
ERROR:Xst:868 - "sea_top.v" line 68: Index out of range for fmuxl_out.
ERROR:Xst:868 - "sea_top.v" line 87: Index out of range for key_r_mux.
ERROR:Xst:868 - "sea_top.v" line 87: Index out of range for fmuxr_out.
ERROR:Xst:868 - "sea_top.v" line 99: Index out of range for key_l_mux.
ERROR:Xst:868 - "sea_top.v" line 99: Index out of range for key_r_mux.
ERROR:Xst:868 - "sea_top.v" line 99: Index out of range for key_l.
ERROR:Xst:868 - "sea_top.v" line 99: Index out of range for key_r.
ERROR:Xst:868 - "sea_top.v" line 165: Index out of range for enc_rdata.
ERROR:Xst:868 - "sea_top.v" line 165: Index out of range for data_l_mux.
ERROR:Xst:868 - "sea_top.v" line 183: Index out of range for enc_ldata.
ERROR:Xst:868 - "sea_top.v" line 183: Index out of range for data_r_mux.
ERROR:Xst:868 - "sea_top.v" line 195: Index out of range for data_l_mux.
ERROR:Xst:868 - "sea_top.v" line 195: Index out of range for data_r_mux.
ERROR:Xst:868 - "sea_top.v" line 195: Index out of range for gn_key.
ERROR:Xst:868 - "sea_top.v" line 195: Index out of range for enc_ldata.
ERROR:Xst:868 - "sea_top.v" line 195: Index out of range for enc_rdata.
regards
kanimozhi
Hi kanimozhi,
For example, Looking at your one of the wire declarations, wire [nr:0] key_r [nby2-1 :0];
may be you wanted to have wire [nby2-1 :0] key_r [nr:0];
Regards,
dcreddy
Yes ya, thank u, i didn't noticed this one, thank u
