hi,
the code i have written to handle timer0 interrupt .but isr is not executing ......what is problem in my code .the compile is Micro C compiler
Code C - [expand ] 1
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
void timer_init( void ) ;
void interrupt ( void )
INTCON.TMR0IF = 0 ;
TMR0L= 0X00 ;
INTCON.TMR0IE = 1 ;
T0CON.TMR0ON = 1 ;
main( )
timer_init( ) ;
while ( 1 ) ;
INTCON.GIE = 1 ; //globle interrupt enable
INTCON.PEIE = 1 ; //peripharel interrupt enable
INTCON.TMR0IF = 0 ; //clear the timer0 flag
TMR0L= 0x00 ; //timer0 reg with initial count
//prescalar value 1:256
T0CON.T0PS0 = 0 ;
T0CON.T0PS1 = 0 ;
T0CON.T0PS2 = 0 ;
T0CON.PSA = 0 ; //prescaler is assigned to timer0
//T0SE=0;
T0CON.T0CS = 0 ;
T0CON.T08BIT = 1 ; //use internal clock or timer mode
INTCON.TMR0IE = 1 ; //enable the timer0 by setting TRM0IE flag
T0CON.TMR0ON = 1 ;
