Problem in interfacing Xbee with at89s51 microcontroller
harisharanyp
Our project has simple task of sending some text from the laptop(one end) to the microcontroller(other end). Laptop and microcontroller are to be connected using wwireless connection. We have :two series2 XBees; two Xbee breakout boards (one with USB and another with DB9 port); microcontroller. We want to interface one Xbee with an at89s51 microcontroller. can anyone please guide us in interfacing these two? do we need to use a level-shifter at the tx-rx pins of xbee?
kindly help.
yes of course bro, the levels given by the serial xbee pins are ttl with -7 and 7 volts. so what you need to do is to make these levels 0 and 5 volts inorder for the microcontroller to understand that these are uart data.
Can you suggest which type of level shifter to use ?
i suggest that you should use a comparator of reference 0 and threshold 5v so if signal is -7 it will give 0v and if signal is 7v it will give 5v.
regards.
regards.
