problem in GF(2^8) multiplication using matlab
ahmeddeia
Member level 2
Member level 2
Egypt
Al salam alikom
h r u all? i hope ur are fine
well if i want to multiply 135 by 2 as both are hexadecimals using GF(2^8) multiplication rule by hand we get the decimal result =21
but when i define them in matlab as GF elements---> the result become= 19 ??? well what wrong???
knowing that i use the following command:
gf(135,8)*gf(2,8)
and the result is
ans = GF(2^8) array. Primitive polynomial = D^8+D^4+D^3+D^2+1 (285 decimal)
Array elements =
19
can u please help me??
thanks and salam alikom
hi Ahmeddeia ,
i could n't find any problem with Matlab
Actually the Matlab
gf(135,8)*gf(2,8)
here 135,2 are Decimal
so hex representation is 87 and 02 ...
Actually matlab computes
gf(hex2dec('87'),8)*gf(hex2dec('02'),8)
Array elements =
     19
Also in the GF(2^8 )
The elements of X must be
integers between 0 and 2^M-1
0 -255
and hex 135 is decimal 309 and obviously outside the range
so when you try to multiply hex 135 and 02
matlab will issue this warning
gf(hex2dec('135'),8)*gf(hex2dec('02'),8)
??? Error using ==> gf.gf
X must be between 0 and 2^m-1
blooz
Al salam alikom
thanks Blooz for ur reply, pls try to multiply both 135 and 2 in GF(2^8) by hand not by matlab and u will find that the result is 21 not 19
so there is a problem in matlab input for this command.
thanks again for ur reply, i really appreciate it
salam alikom
Al salam alikom
salam alikom
Are trying to multiply decimal 135 and 2
if it is then the manual calculation
hex 87 * hex 02
answer is hex 10E
then after modular reduction that is 10E xor 11D
Answer is hex 13
decimal 19
Yes you can have 21 as answer ,then you would be probably using some other modulus other than 11D
for Eg .AES uses 11B instead of 11D and
so the Answer will be
10E xor 11B
hex 15
decimal 21
by default matlab uses 11D as the primitive polynomial
As per your requirement
you can use the following command
gf(135,8,283)*gf(2,8,283)
ans = GF(2^8) array. Primitive polynomial = D^8+D^4+D^3+D+1 (283 decimal)
Array elements =
     21
Al salam alikom
well Blooz, i really thank u for ur reply, it really helped me....
but when i used it matlab, it gives a warning that this polymonial is not the default and also it tells me that i can use gftable command for faster computations
Warning: PRIM_POLY must be a primitive polynomial.
> In gf.gf at 96
> In gf.gf at 96
Warning: Lookup tables not defined for this order 2^8 and
primitive polynomial 283. Arithmetic still works
correctly but multiplication, exponentiation, and
inversion of elements is faster with lookup tables.
Use gftable to create and save the lookup tables.
> In gf.gettables at 35
In gf.mtimes at 20
> In gf.gf at 96
In gf.mtimes at 25
Array elements =
21
so how can i use it within writing m-files within a user defined function
thanks again for ur help, i really appreciate it
salam alikom
First create the gftable so that it will accelerate the calculations
GFTABLE(M,PRIM_POLY)
gftable(8,283)
then for this particular case you can suppress the warning
type this command
warning off comm:gf:primPolyPrim
Al salam alikom
thanks for ur help, it really helped me
salam alikom
anybody can give idea to shifting rows in aes in matlab?
salam alikom
you will find a matlab command called cirshift or something like that, I don't remember.
However this will help you to make shift rows in AES
thanks,
Salam alikom
