[51] problem in Generating random nmber using rand() function in embedded c
MANO.5
Member level 1
Member level 1
i modified the example random number generation program from keil help section.
keil example program
#include <stdlib.h>
#include <stdio.h> /* for printf */
void tst_rand (void) {
  int i;
  int r;
  for (i = 0; i < 10; i++) {
    printf ("I = %d, RAND = %d\n", i, rand ());
my program was
 #include<reg51.h>
 #include <stdlib.h>
 sfr lcd_data_pin=0xA0;//p2 port
sbit rs=P1^0;
sbit rw=P1^1;
sbit e=P1^2;
void delay(unsigned int count)    //Function to provide delay
    int i,j;
    for(i=0;i<count;i++)
    for(j=0;j<1275;j++);
void lcd_cmd(unsigned char value)
	lcd_data_pin = value;
	rs=0;
	rw=0;
	e=1;
	delay(1);
	e=0;
	delay(1);
void lcd_data(unsigned char value)
	lcd_data_pin =value;
	rs=1;
	rw=0;
	e=1;
	delay(1);
	e=0;
	delay(1);
void lcd_init()
         lcd_cmd(0x38);
	lcd_cmd(0x0e);
	lcd_cmd(0x01);
	lcd_cmd(0x80);
void lcd_string(unsigned char *disp)	 //LCD string function
	char x;
	for(x=0;disp[x]!=0;x++)
		lcd_data(disp[x]);
  void lcd_data_int(int time_val)		//  to send three digit number
	int int_amt;
    int_amt = time_val/1000;
	lcd_data(int_amt+48);
	time_val = time_val%1000;
	int_amt = time_val/100;
	time_val = time_val%100;
	int_amt = time_val/10;
	int_amt = time_val%10;
  unsigned int i;
  i= rand();
 lcd_cmd(0x80);
lcd_string("number: ");
delay(250);
lcd_cmd(0xc0);
 lcd_data_int(i);
void main()
lcd_init();
  while(1)
   	  tst_rand ();
when i compile this code it gives 3 warnings and when simulate in proteus it was blinking...no output
this is the 3 warnings from keil
Rebuild target 'Target 1'
compiling rand.c...
linking...
*** WARNING L7: MODULE NAME NOT UNIQUE
MODULE: G:\PROGRAM FILES\KEIL\C51\LIB\C51S.LIB (RAND)
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
SYMBOL: RAND
MODULE: rand.obj (RAND)
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
SYMBOL: RAND
ADDRESS: 0129H
Program Size: data=15.0 xdata=0 code=461
creating hex file from "rand"...
"rand" - 0 Error(s), 3 Warning(s).
So help me to solve this issue
try
#include <stdlib.h>     /* srand, rand */
have you thought how you would seed the generator - it is only pseudo-random so unless you seed differently each time you run you will get the same sequence of numbers
Hello horace1,
ya it's pseudo-random .But i want to know what is this error & how to solve this
thank you horace1,
I am tried in keil also.But waiting for answers.. here also looking forward.pls anybody compile and post the result to know there is problem in my keil installation..
on different pc it was compiled without any error or warnings.But no output in lcd..so please somebody check is there any mistakes in program...........
as u are using rand function but whenever u feed same value it will return same output. so u have to feed different value as input so u will get really random numbers.
When i was simulating this program in proteus it didn't displaying anything...giving same number is not problem ..the problem is not displaying anything.....
