I want to decode the dtmf tones sent from mobile's microphone but i have stuck in this. I am not getting output. I think there may be some problem in earphones' output .. Tell me how to connect earphone to dtmf decoder's IC. I am using MT8870.
yes, i m using the same datasheet.
I have cutted my earphone's wire and got four wires of colour green, red, and 2 yellow. than i connected green and red wires to pin no. 2 and ground respectively and i have also tried the reverse combination. Am i doing the right or is there any other way to give input to mt 8870 ic.
Hey man, I've been using a DTMF decoder CM8870, I've opened the PCB mike box, and have connected the right,left and ground wires to a male jack and then connected to a female jack and again to a male jack pin..the pin had sleeve,tip and ring..nd to sleeve, right to tip and left to ring. If your's is working, could you please send me the hardware design part of it..I'm not sure I've connected mine right..
