Problem in display correct values of the temperature sensor
caramelz
Junior Member level 2
hi I'm using Pic18f4520, the temperature sensor doesnt give the correct values. the values isnt consistent at all too.
Temperature sensor is connect to AN12 of the IC
I display the ADC reading into the LCD, the values kept jumping from 50 , 70, 100 back to 50.
Can anyone tell me whats wrong with it. thanks
I'm using a LM35 sensor.
ADCON2=0b10001010;
void temperature(void)
	unsigned int temp;
	char degree[4]="   ";
	unsigned int me;
	temp=ADCRead(12);
	me=temp;
	Init_LCD();
	itoa(me,degree);
		i=0;
		W_ctr_8bit(0x80);
		while (degree[i]){
			W_data_8bit(degree[i]);
			i++;
unsigned int ADCRead(unsigned int ch)
	if(ch>13)return 0;
	ADCON0=0x00;
	ADCON0=(ch<<2);
	ADCON0bits.ADON=1;
	Delay10TCYx(5);
	ADCON0bits.GO = 1;
	while(ADCON0bits.DONE);
	ADCON0bits.ADON=0;
	return (ADRESH*256+ADRESL);
Where is ADCON1 settings?
TRISBbits.TRISB0 = 1;
ADCON1 = 0b00000001;
//or
ADCON1 = 0b00000010;
//or
ADCON1 = 0b00000000;
Mention Fosc used so that ADCON2 value can be calculated. Put Init_LCD(); in main() before while(1) loop.
I'm using 20Mhz crystal
ADCON0=0b00000001;
ADCON1=0b00000111;
ADCON2=0b10001010;
the sensor is connected in RB0 CH12.
Sensor Connection: 5V, GND, RB0.
I just changed the sensor to CH8(RB2) as to minimize the port usage cos i have 8 other ADC CH for measuring the batteries.
yeah I had set the trisB to Input for RB2
