[SOLVED] problem in defining bits in Winavr
shahbaz.ele
Advanced Member level 1
Islamabad, Pakistan
dear all
I want to set and clear the bits of MCUCR register
but I do not know how to define the SM0,1,2 bits and SE bit and how to set these bits.
you can use following instructions to set or clear bits of any register
MCUCR |= (1<<0); //to set bit 0 of MCUCR
MCUCR |= (1<<7); //to set bit 7 of MCUCR
MCUCR &= ~(1<<0); //to  clear bit 0 of MCUCR
MCUCR &= ~(1<<7); //to clear bit 7 of MCUCR
Note that the bits of each register are defined in the header file with the name used in the datasheet.
For example for mega8 the header iom8.h includes
/* MCUCR */
#define SE	7
#define SM2	6
#define SM1	5
#define SM0	4
#define ISC11	3
#define ISC10	2
#define ISC01	1
#define ISC00	0
so this allows you to use bit names instead of numbers if you want
MCUCR |= (1<<ISC00); //to set bit 0 of MCUCR
MCUCR |= (1<<SE); //to set bit 7 of MCUCR
also take a look at https://www.edaboard.com/blog/861/
I like to use
#define SETBIT(ADDRESS,BIT) (ADDRESS |= (1<<BIT))
#define CLEARBIT(ADDRESS,BIT) (ADDRESS &= ~(1<<BIT))
SETBIT(MCUCR,ISC00); // //to set bit 0 of MCUCR
CLEARBIT(MCUCR,ISC00)  //to clear bit 0 of MCUCR
Alex
