[SOLVED] Problem in default arithmetic for ' i ' variable.
Exactly!!!
And I try in XC8 and MPLAB, and is the same result!!!
The question is: How did he build the program???
hehehe...
Hi guys,
I dunno how to place my zip file at here.. But i need to tell something that i using MPLAB in Hi-Tech language.The Coding above is successful build in a hex file and it can blinking !!! Weird ...
Regards,
YY
This is my zip file :)
  • Test.7z
For me it gave error, undefined identifier. I am using Hi Tech PICC 9.83 with MPLAB IDE 8.92.
That's what we were talking about!!!
My versions is MPLAB 8.89 and HI-TECH C Compiler for PIC10/12/16 MCUs (PRO Mode) V9.83
How he managed to generate the hex???
Maybe he is kidding. He compiled the code with i defined as char or int and then removed the declaration line and then took a screenshot. :lol:
Here is my print screen.Why my MPlab with Hi Tech ANSI C Compiler can success?
Now i see the problem!!!
Using old version of mplab (like screenshot) 8.5 and HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode) V9.70 its is possible!!!
Trying to compile, first click on build, we receive the message:
"Error [192] C:\Temp\MCU\Microchip\PIC16F628A\Blink\main.c; 11.6 undefined identifier "i""
If click again, "********** Build successful! **********"
This occurs because file generated .P1 .
I believe this is why.
Using a new version, its break in error message!!!
Hi nagkiller,
You're correct.It will failed at the first time,but will success when rebuild again. What actually is the .P1. ? i want go to study on it.
Regards,
YY:grin:
interesting so this is compiler bug and i also know about what is .P1. ?
P1 is a file generated by compiler... your code is a (p-code) precompiled translated before creating hex file.
Ex: if you project name is test and the source code is main.c, the compiler generate main.pre and main.p1... if the code is ok, he generate the rest:
test.as, test.cof, test.hex, test.hxl, test.lst, test.map, test.obj, test.rlf, test.sdb, test.sym, funclist, startup.as, startup.lst, startup.obj, startup.rlf...
In the manual, may have something about it, or as said before, this is a bug!!
Reactions: WhyWhy
    WhyWhy
