[SOLVED] Problem in Coding using MPLAB
shahbaz.ele
Advanced Member level 1
Islamabad, Pakistan
// Control signal pin direction
#define RW_TRIS TRISCbits.TRISC13
#define RS_TRIS TRISCbits.TRISC14
#define E_TRIS TRISCbits.TRISC15
// Data signals and pin direction
#define DATA LATF,LATA // Port for LCD data
#define DATAPORT PORTF,PORTA
#define TRISDATA TRISF,TRISA // I/O setup for data Port
Here is my code i want to define DATA as combined ports F and A (0 to 6 portF and 1 bit of porta) of dsPIC30F3014
hai shahbaz,
i think you can define as follows
#define DATA (portF shift bits to get 0 to 6)|(portA shift bits)
I don't think this will work. LAT and PORT registers are memory mapped same as all the rest of SFRs as data memory addresses 0x0000 to 0x07ff. LATA is at 0x02C4 and LATF is at 0x02F2. I don't think there is a way to do really fast access to those two (of course you can write data to some variable and then split them into separate latches one by one, but that's the only option i guess)
From that i understand that you're using 16-bit mcu (you have more than 8 bits per port). If that's the case you can write whole byte to bits 0-7 like that:
LATB&=0xff00;
LATB|=(0x0000|DATA);
this way you preserve whatever was on higher bits and overwrite anything that was on lower bits with data.
to manipulate RS and EN you can simply use
_LATB9=0;
_LATB8=1; etc. (at least in C30 you can do that, because definitions for single port bits are in header file for particular micro)
