Problem in AT+CPBR Command with PIC18F452
speedEC
Full Member level 6
Dear all,
I can able to send and receive all AT Commands except (AT+CPBR and AT+CMGR Commands). I want to store all the phone book entries (already stored in SIM) into array. So, When I start the GSM Modem/Module, I issue AT+CPBR=1,250 command and read the Phone Book (SIM) and Store the Phone numbers into the array. If I issue AT+CPBR command, it executes well and return the phone book records and hangs. I don't know why. All other commands work fine. Any help? I give you my code here. Pl go thro' that and pl let me know if you found any errors. The code could be little large. Inconvenience regretted.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
/* MAKE RECEIVE AS HIGH INTERRUPT PRIORITY */
#pragma code rx_interrupt = 0x8 //high interrupt vector
void rx_int (void)
    if (PIR1bits.RCIF){
        PIR1bits.RCIF = 0; // clear interrupt flag
        rx_handler();
    return;
#pragma code
#pragma interrupt rx_handler // changed the interrupt to interruptlow
void rx_handler (void)
  unsigned char input;
  input = ReadUSART();
    switch(input){
            case '\x0A': // if line feed detected in the GSM output i.e. '\n'
                        break;
            case '\x0D': // if carriage return detected i.e. '\r'
                        gsmOutput_c[i] = '\x00';
                        lenOfGSMOutput = strlen((char*)gsmOutput_c);
                        if (lenOfGSMOutput > 0){
                            i = 0;
                            lenOfGSMOutput = 0;
                            showGSM_DATA(gsmOutput_c);
                            *gsmOutput_c = 0;
                            PIE1bits.RCIE = 1; // enable receive interrupts
                        break;
        default: // if characters received
                        if(i < 80){
                            gsmOutput_c[i] = input;
                            i++;
                        else{
                            i = 0;
                break;
        }//end for switch
//Processing and Validating GSM_MODEM_OR_MODULE OUTPUT
void showGSM_DATA(char gsmOutput_s[]){
    if (strcmppgm2ram(gsmOutput_s, (const far rom char*)"OK") == 0){
       OK = TRUE;
    if (strcmppgm2ram(gsmOutput_s, (const far rom char*)"ERROR") == 0){
       OK = FALSE;
     return;
    if (strcmp(gsmOutput_s, NO_CARRIER) == 0){
        WriteCmdXLCD(CLR_LCD);
        while(BusyXLCD());
        WriteCmdXLCD(HOME_LCD);
        while(BusyXLCD());
        putrsXLCD("NO CARRIER");
     return;
    if (strcmp(gsmOutput_s, Error) == 0) {
        while(BusyXLCD());
        while(BusyXLCD());
        putrsXLCD("Error");
     return;
    if (strcmppgm2ram(NextGSMCmd, (const far rom char*) "PhBk_Stored") == 0){
        *NextGSMCmd = 0;
        *gsmOutput_s = 0;
        while(BusyXLCD());
        while(BusyXLCD());
        if (OK == TRUE){
            OK = FALSE;
            putrsXLCD("PH BK READ - OK");
        else{
            putrsXLCD("PH BOOK ERROR");
     return;
    if (strlen(gsmOutput_s) > 5){
        strBuff = 0;
        i = 0;
        while(i < 5){
            strBuff[i] = gsmOutput_s[i];
            i++;
        strBuff[i] = '\x00';
        i = 0;
        if (strcmppgm2ram(strBuff, (const far rom char*)"+CPBR") == 0){
            *strBuff = 0;
            if (strcmppgm2ram(NextGSMCmd, (const far rom char*) "store_PhBk_Into_Array") == 0){
                strcpypgm2ram(NextGSMCmd, (const far rom char*) "PhBk_Stored");
Here the problem araises. If I commented as follows it works fine. But, If I uncomment the following XLCD commands "gsmOutput_s" displayed correctly and hangs here.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
                *gsmOutput_s = 0;
                while(BusyXLCD());
                while(BusyXLCD());
                putrsXLCD("gsmOutput_s");
          return;
void main (void)
    TRISA = 0; // RS, R/W, E pins of LCD
    /* Configure all PORTB pins for output except RB0*/
    TRISB = 0; // RB0 as Input for Interrupt
    TRISD = 0; // set PORTD as Output for LCD (D4 to D7)
    PORTB = 0; // Initialize portB
    PORTD = 0; // Initialize PORTD
    /* Make receive interrupt high priority */
    IPR1bits.RCIP = 1;
    /* Enable interrupt priority */
    RCONbits.IPEN = 1;
    /* Enable all high & low priority interrupts */
    INTCONbits.GIEH = 1;  // interrupt on RB0
    OpenXLCD(FOUR_BIT & LINE_5X7); // Open and Initialize LCD
    * Open the USART configured as
    * 8N1, 9600 baud, in polled mode
    OpenUSART (USART_TX_INT_OFF &    //Set and Open Serial Port
               USART_RX_INT_ON &
               USART_ASYNCH_MODE &
               USART_EIGHT_BIT &
               USART_CONT_RX &
               USART_BRGH_HIGH, 25);
    i = 0;
    OK = FALSE;
    strcpypgm2ram(NextGSMCmd, (const far rom char*) "store_PhBk_Into_Array");
    while (BusyUSART());
    putrsUSART((const far rom char *)"AT+CPBR=1");
    putcUSART(0x0A);
    putcUSART(0x0D);
    /* Loop forever */
    while (1);
advance thanks.
