Jayakumar.azetech
Newbie level 2
I am new to the programming, I facing a with a problem to display the signed valued on the LCD, I get the correct output with the GCC simulation, but unfortunately on to the hardware I get some garbage value.
just to display any signed value, like -156 on the 16x2
>>when it tried to display it on the display i get, (+0
any help!!!
my code,
any help would be appreciate!!!!!!!!!!!!!!!!!!!!!!!!!!
any help!!!
my code,
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 l_Current_Signed_Value = -850; Display_Decimal((float)l_Current_Signed_Value); -------------------------------------------------------------- void Display_Decimal(int32 value) { if((value/100000000)!=0) Decimal(value,9); else if((value/10000000)!=0) Decimal(value,8); else if((value/1000000)!=0) Decimal(value,7); else if((value/100000)!=0) Decimal(value,6); else if((value/10000)!=0) Decimal(value,5); else if((value/1000)!=0) Decimal(value,4); else if((value/100)!=0) Decimal(value,3); else if((value/10)!=0) Decimal(value,2); else if(value!=0) Decimal(value,1); else LCD_Data('0'); } ------------------------------------------------ void Decimal(int32 value,int8 digit) { switch(digit) { case 9: LCD_Data((value/100000000)+0x30); value%=100000000; case 8: LCD_Data((value/10000000)+0x30); value%=10000000; case 7: LCD_Data((value/1000000)+0x30); value%=1000000; case 6: LCD_Data((value/100000)+0x30); value%=100000; case 5: LCD_Data((value/10000)+0x30); value%=10000; case 4: LCD_Data((value/1000)+0x30); value%=1000; case 3: LCD_Data((value/100)+0x30); value%=100; case 2: LCD_Data((value/10)+0x30); value%=10; case 1: LCD_Data(value+0x30); } }
