NaneBL
Newbie level 3
Hi friend. I am programming a slave modbus device into a Spartan 6 and I get this warning in map implement:
WARNINGhysDesignRules:2410 - This design is using one or more 9K Block RAMs
(RAMB8BWER). 9K Block RAM initialization data, both user defined and
default, may be incorrect and should not be used. For more information,
please reference Xilinx Answer Record 39999.
I have looked for about it, and I have found some solutions, but I do not understand well.
I use ISE 13.1. Do you know how select 18k block ram in ISE Design for implemention?
I think this is the code which use my 9k block ram.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
Entity fifo is
Port ( CLK : in std_logic;
RESET : in std_logic;
RD : in std_logic;
WR : in std_logic;
W_DATA : in std_logic_vector(7 downto 0);
EMPTY : out std_logic;
FULL : out std_logic;
R_DATA : out std_logic_vector(7 downto 0));
END fifo;-- entity declarations ends
Architecture A_fifo of fifo is
Type Mem is array (255 downto 0) of std_logic_vector( 7 downto 0);
Signal Memory : Mem;
Signal ReadPointer : std_logic_vector(7 downto 0);
Signal WritePointer : std_logic_vector(7 downto 0);
Signal ByteCounter : std_logic_vector(8 downto 0);
Signal WriteEnable : std_logic;
Signal ReadEnable : std_logic;
Signal FifoFull : std_logic;
Signal FifoEmpty : std_logic;
Begin
-- Ram memory --
Write_Process : Process(clk)
Begin
if (clk'event and clk = '1') then
if ( WriteEnable = '1') then
Memory(Conv_Integer(WritePointer)) <= w_data;
end if;
if ( ReadEnable = '1' ) then
r_data <= Memory(Conv_Integer(ReadPointer));
end if;
end if;
end process;
--r_data <= Memory(Conv_Integer(ReadPointer));
-- Pointers control --
ReadWriteFifoOut : Process(Clk,Reset)
Begin
IF ( Reset = '1') then
ReadPointer <= "00000000";
WritePointer <= "00000000";
ByteCounter <= "000000000";
ELSIF(Clk'event and Clk = '1') then
IF ( WriteEnable = '1' and ReadEnable = '0') then
WritePointer <= WritePointer + 1;
ByteCounter <= ByteCounter + 1;
END IF;
IF ( ReadEnable = '1' and WriteEnable = '0') then
ReadPointer <= ReadPointer + 1;
ByteCounter <= ByteCounter - 1;
END IF;
IF ( ReadEnable = '1' and WriteEnable = '1' ) then
END IF;
END IF;
END process;
-- Combinatorial Logic --
FifoEmpty <= '1' when ( ByteCounter = "000000000") else '0';
FifoFull <= ByteCounter(8);
Full <= FifoFull;
Empty <= FifoEmpty;
WriteEnable <= '1' when ( Wr = '1' and FifoFull = '0') else '0';
ReadEnable <= '1' when ( Rd = '1' and FifoEmpty = '0' ) else '0';
END A_fifo;--Architecture Ends
