priority encoder using with select in VHDL
sougata_vlsi13
Member level 4
Member level 4
India
I am facing problem in writing the code of priority encoder using with select.....please help me in this regard
i have written the code using when else but i am nt getting how to select the expression using with select.As with select is equivalent to case expression some defined conditions are ncessary .....how to define that
with select is like this:
with a select
  b <= "000" when 0,
       "001" when 1,
       "010" when 2,
--etc
But case statements can be put inside a clocked process for synchronisation, with..select cannot.
Sir...is there any specific libraries i have to mention along with that code becoz 0,1,2 are all integers
so? if a is an integer then there is no problem.
Refer back to the original response that TrickyDicky had to this thread...post your code. If you have none yet, then write some first and then ask questions if it doesn't work as you expected.
Kevin
