imranahmed
Advanced Member level 3
- Joined
- Dec 4, 2011
- Messages
- 822
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Karachi,Pakistan
- Activity points
- 6,534
Please let me know that I am some changing in Print.h and Print.cpp, make another files
name SevSEG.h and SevSEG.cpp for displaying values on 3 digit 7-segment display by using
print function with Arduino UNO.
But some errors during compiling like Test:19: error: cannot declare variable 'Ss' to be of abstract type 'SevSEG'
E:\Arduino IDE\arduino-1.0.6\libraries\SevSEG/SevSEG.h:36: note: because the following virtual functions are pure within 'SevSEG':
E:\Arduino IDE\arduino-1.0.6\libraries\SevSEG/SevSEG.h:44: note: virtual size_t SevSEG::write(uint8_t).
but what can I do for fix this problem or how to make it proper?
Header File:
CPP File:
Header File:
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include "Arduino.h"
#include "Print.h"
#include "SevSEG.h"
// Public Methods //////////////////////////////////////////////////////////////
/* default implementation: may be overridden */
size_t SevSEG::write(const uint8_t *buffer, size_t size)
size_t n = 0;
while (size--) {
n += write(*buffer++);
return n;
size_t SevSEG::print(const __FlashStringHelper *ifsh)
PGM_P p = reinterpret_cast<PGM_P>(ifsh);
size_t n = 0;
while (1) {
unsigned char c = pgm_read_byte(p++);
if (c == 0) break;
n += write(c);
return n;
size_t SevSEG::print(const String &s)
return write(s.c_str(), s.length());
size_t SevSEG::print(const char str[])
return write(str);
size_t SevSEG::print(char c)
return write(c);
size_t SevSEG::print(unsigned char b, int base)
return print((unsigned long) b, base);
size_t SevSEG::print(int n, int base)
return print((long) n, base);
size_t SevSEG::print(unsigned int n, int base)
return print((unsigned long) n, base);
size_t SevSEG::print(long n, int base)
if (base == 0) {
return write(n);
} else if (base == 10) {
if (n < 0) {
int t = print('-');
n = -n;
return printNumber(n, 10) + t;
return printNumber(n, 10);
} else {
return printNumber(n, base);
size_t SevSEG::print(unsigned long n, int base)
if (base == 0) return write(n);
else return printNumber(n, base);
size_t SevSEG::print(double n, int digits)
return printFloat(n, digits);
size_t SevSEG::println(const __FlashStringHelper *ifsh)
size_t n = print(ifsh);
n += println();
return n;
size_t SevSEG::print(const Printable& x)
return x.printTo(*this);
size_t SevSEG::println(void)
size_t n = print('\r');
n += print('\n');
return n;
size_t SevSEG::println(const String &s)
size_t n = print(s);
n += println();
return n;
size_t SevSEG::println(const char c[])
size_t n = print(c);
n += println();
return n;
size_t SevSEG::println(char c)
n += println();
return n;
size_t SevSEG::println(unsigned char b, int base)
size_t n = print(b, base);
n += println();
return n;
size_t SevSEG::println(int num, int base)
size_t n = print(num, base);
n += println();
return n;
size_t SevSEG::println(unsigned int num, int base)
n += println();
return n;
size_t SevSEG::println(long num, int base)
n += println();
return n;
size_t SevSEG::println(unsigned long num, int base)
n += println();
return n;
size_t SevSEG::println(double num, int digits)
size_t n = print(num, digits);
n += println();
return n;
size_t SevSEG::println(const Printable& x)
size_t n = print(x);
n += println();
return n;
// Private Methods /////////////////////////////////////////////////////////////
size_t SevSEG::printNumber(unsigned long n, uint8_t base) {
char buf[8 * sizeof(long) + 1]; // Assumes 8-bit chars plus zero byte.
char *str = &buf[sizeof(buf) - 1];
*str = '\0';
// prevent crash if called with base == 1
if (base < 2) base = 10;
do {
unsigned long m = n;
n /= base;
char c = m - base * n;
*--str = c < 10 ? c + '0' : c + 'A' - 10;
} while(n);
return write(str);
size_t SevSEG::printFloat(double number, uint8_t digits)
size_t n = 0;
if (isnan(number)) return print("nan");
if (isinf(number)) return print("inf");
if (number > 4294967040.0) return print ("ovf"); // constant determined empirically
if (number <-4294967040.0) return print ("ovf"); // constant determined empirically
// Handle negative numbers
if (number < 0.0)
n += print('-');
number = -number;
// Round correctly so that print(1.999, 2) prints as "2.00"
double rounding = 0.5;
for (uint8_t i=0; i<digits; ++i)
rounding /= 10.0;
number += rounding;
// Extract the integer part of the number and print it
unsigned long int_part = (unsigned long)number;
double remainder = number - (double)int_part;
n += print(int_part);
// Print the decimal point, but only if there are digits beyond
if (digits > 0) {
n += print(".");
// Extract digits from the remainder one at a time
while (digits-- > 0)
remainder *= 10.0;
int toPrint = int(remainder);
n += print(toPrint);
remainder -= toPrint;
return n;
CPP File:
#ifndef SevSEG_h
#define SevSEG_h
#include <inttypes.h>
#include <stdio.h> // for size_t
#include "WString.h"
#include "Printable.h"
#include "Print.h"
#define DEC 10
#define HEX 16
#define OCT 8
#define BIN 2
class SevSEG : public Print
private:
size_t printNumber(unsigned long, uint8_t);
size_t printFloat(double, uint8_t);
public:
virtual size_t write(uint8_t) = 0;
virtual size_t write(const char *str);
virtual size_t write(const uint8_t *buffer, size_t size);
size_t print(const __FlashStringHelper *);
size_t print(const String &);
size_t print(const char[]);
size_t print(char);
size_t print(unsigned char, int = DEC);
size_t print(int, int = DEC);
size_t print(unsigned int, int = DEC);
size_t print(long, int = DEC);
size_t print(unsigned long, int = DEC);
size_t print(double, int = 2);
size_t print(const Printable&);
size_t println(const __FlashStringHelper *);
size_t println(const String &s);
size_t println(const char[]);
size_t println(char);
size_t println(unsigned char, int = DEC);
size_t println(int, int = DEC);
size_t println(unsigned int, int = DEC);
size_t println(long, int = DEC);
size_t println(unsigned long, int = DEC);
size_t println(double, int = 2);
size_t println(const Printable&);
size_t println(void);
#endif
