quan228228
Full Member level 4
The following are primetime report:
Startpoint: cheetah_top/u_mcu/i_core/i_cpu/i_biu/ale_neg_reg
(rising edge-triggered flip-flop clocked by clk30')
Endpoint: ALE (output port clocked by clk30)
Path Group: outputs
Path Type: max
Point Incr Path
clock clk30' (rise edge) 16.00 16.00
clock network delay (propagated) 5.61 * 21.61
cheetah_top/u_mcu/i_core/i_cpu/i_biu/ale_neg_reg/CK (FFSDRHD4X)
0.00 21.61 r
cheetah_top/u_mcu/i_core/i_cpu/i_biu/ale_neg_reg/QN (FFSDRHD4X)
0.36 * 21.97 f
cheetah_top/u_mcu/i_core/i_cpu/i_biu/U120/Z (NAND2HD4X)
0.12 * 22.09 r
cheetah_top/u_mcu/i_core/i_cpu/i_biu/mem_ale (VEO_DW8051_biu_rom_addr_size13_1)
0.00 * 22.09 r
cheetah_top/u_mcu/i_core/i_cpu/mem_ale (VEO_DW8051_cpu_ram_2561_rom_addr_size13_extd_intr1_1)
0.00 * 22.09 r
cheetah_top/u_mcu/i_core/mem_ale (VEO_DW8051_core) 0.00 * 22.09 r
cheetah_top/u_mcu/ale (veo_8051) 0.00 * 22.09 r
cheetah_top/U843/Z (AND3HD4X) 0.29 * 22.38 r
cheetah_top/ale_out (cheetah_top) 0.00 * 22.38 r
PAD_ALE/I (PB4W_13) 0.00 * 22.38 r
PAD_ALE/U1/Z (BUFHD20X) 0.19 * 22.57 r
PAD_ALE/PLBI4N_ins/P (PLBI4N) 1.66 * 24.23 r
PAD_ALE/PAD (PB4W_13) 0.00 * 24.23 r
ALE (inout) 0.00 * 24.23 r
data arrival time 24.23
clock clk30 (rise edge) 32.00 32.00
clock network delay (propagated) 0.00 32.00
clock uncertainty -0.15 31.85
output external delay -10.00 21.85
data required time 21.85
data arrival time -24.23
slack (VIOLATED) -2.38
The register (start point) is trigged by rising edge of clock "clk30". The output "ALE" is also clocked by clock "clk30".
Why the timing calculation starts from 16 (the negedge of clk30)?
Thanks!
David
Path Group: outputs
Path Type: max
Point Incr Path
0.00 21.61 r
0.36 * 21.97 f
0.12 * 22.09 r
0.00 * 22.09 r
0.00 * 22.09 r
Thanks!
David
