garg29
Advanced Member level 1
hi,
I am trying to rectify a AC voltage ranging from 0-3 volts using a precision rectifier.
As shown in the diagram the final output is full wave rectified signal i want to know how can I feed this signal directly to ADC I mean the voltage is going up & Down in the curve. For proper reading I think we need pure DC, but , in this case the output is full wave, how will be the value (that will be displayed) be stable?
If I use a resisor & condensor (100 ohm + 1uF) on output the change in voltage is reflected after a long time. How can I use this precisiion rectifier ? I'm using PIC microcontoller 16F877 to display the voltage on lcd & It's ADC to read the analog input .
Please help me out.
Thanks.With best Regards,
Garg
Please help me out.
Garg
