udhay_cit
Full Member level 6
I'm in need of a very precise (zero phase shifting) zero crossing detector for 50Hz AC line. I have tried with some of ZCD circuit but the output square wave has some distortion (jitter like effect).
The application of this circuit is TanDelta measurement. The ZCD circuit required for both voltage & current waveform so there should not be phase shifting by introducing a pass filter (capacitor) or step down transformer (inductor) for the filtering application.
I consider three way of eliminating the noise.
1. Using a DSP to remove the noise at the zero crossing level by sample & average.
2. Converting the AC waveform into dc by using ZCD circuit. The jitter present in the zero cross level can be eliminated by a microcontroller at digital level without involving high speed ADC (or DSP).
3. Feeding the output of ZCD to a jitter attenuator IC chip. but i can't find a jitter attenuator IC for 50Hz yet.
I don't know which method is good. Please advice me to handle the problem.
Regards
Udhay
Regards
Udhay
