anasb
Newbie level 3
Hi
I am trying to look for a current measurement circuit that is able to measure an AC current signal whose peak-to-peak is in the range of 10 uA to 100 uA. Basically, I have a circuit whose average supply current is about 50 mA, and the small AC current signal sits on top of it (i.e. the supply current is 50 mA DC + about 50 uA AC). The supply voltage is 12 V (so if a sense resistor is to be used, it should be really small). Note that I want to be able to see the signal on the oscilloscope.
Assume the frequency of the AC current signal is controlled (right now it is 250 kHz, but I can reduce/increase it).
Anybody knows a useful circuit I can buy?
PS: I have been looking at a couple of possible useful products, but not sure if they will solve the problem:
LT1167: http://cds.linear.com/docs/Datasheet/1167fc.pdf
Ultraprecise Current Sense Amplifier Dramatically Enhances Efficiency and Dynamic Range – Design Note 423: http://cds.linear.com/docs/Design%20Note/dn423f.pdf
Sub-uA RMS Current Measurement for Quartz Crystals: http://cds.linear.com/docs/LT%20Journal/LTMag-V17N02-15-SubMicroAmpCurrentMeasurement-Williams.pdf
