preamplifier overvoltage, reverse polarity protection
masudasim
Junior Member level 1
Hello all
I have designed a preamplifier which operates on unipolar supply +10V and draws about 20mA to 40mA depending upon jumper setting.Now i need to add reverse polarity protection as well as overvoltage protection (maximum allowable voltage is +15V)
Kindly tell me is there any simple solution available?
Best Regards
A power zener or unipolar TVS diode and a series resistor. If permanent overvoltage is expected, possibly a PTC or standard fuse.
If enough big resistor can be added and the normal function will not be affected, both over-voltage and reverse protection can be achieved only with the resistor. No diode is needed sometimes.
