Apparently the same vague question has been asked in several forums simultaneously, even the 3v requirement was given as an assumption in a reply and not as part of the the OP requirement
I would suggest you describe clearly what you are trying to do, the voltages and current involved and the linear regulator you intent to use (assuming you want to use a linear regulator)
