rfle
Junior Member level 1
Hello everyone.
In some large power consumption circuits, especially Power Amplifier (PA) the current supply is quite high: 10mA ~ 100 mA. In the layout, how wide are the supply wires (vdd, gnd) to provide that current? If the supply wires are too narrow while the running current is too high, it may cause the wires burning, doesn't it? Further more, the PA should provide 10~20 dBm output signal, which also create a large number of AC current flowing in a signal path, then how large should a signal line be to transmit this current ??
The inductor also play as vdd supply for a PA and for example in 0.18 CMOS process the maximum width is 4 um. Is this wide enough to provide 10~100 mA current. To the best of my knowledge, the rule of thumb is 1 um for 1 mA. So how come people can build PA with 30 dBm output power in such process??
Could anyone provide some information? Thank you
