IRF510 is a MOS transistor, what are you talking about? All transistors which start with IRF are MOSFETs.I tried with irf510 but because it is not a mosfet transistor it caused some problems in the simulation then I did a simulation with irf3708, which gives in the datasheet a drain current about 30 amper on vgs=2.7 v.
Where did you find this information? Are you sure you read the IRF510 datasheet?On the datasheet of irf 510 the dran current around 1p for vgs =5v
I would guess 5uF across the output is going to sink most of the output.
