nalawade
Junior Member level 2
I want make a power supply to feed these IC's
LM35
Pic16f886
Ht12E Encoder
Rf Transmitter.
All the above Ic's require 5 Volts DC supply.
How do I make a power supply for These IC's. All are on the same PCB.
How do I calculate the Power required by a particular IC ?
Suppose an IC requires 5 volt DC supply and we give that IC exact 5 volt supply. ( connect the supply parallel to that IC)
If the maximum current provided by the 5 Volt supply is .5 Amperes .
But the IC requires only .5 mili Amperes of current.
My question is, will that IC draw only 0.5 mili Amperes of current ?
LM35
Pic16f886
Ht12E Encoder
Rf Transmitter.
