power required for spartan 3an
sriharsha.hs
Junior Member level 3
Hi folks,
I am using spartan 3AN (XC3S50AN-4FTG256) for my design. How should I calculate the power required for running the design in FPGA.?
As per my understandings it requires,
VCCint = 1.2 V.
VCC (AUX) = 3.3 V
VCCO (Output supply Voltage)
GND
All pins need to be connected.
Is my understandings are correct because ?
Is it possible to reduce the no of pins connected depending upon the resource used inside the FPGA.?
Any reply accepted.
Thank you.
