sweethomela8
Member level 4
Is there any issues with choosing a switching power regulator that can provide a lot more current than a circuit needs...
for example..
I chose a linear tech, switching regulator capable of delivering up to 8 amps max.
What if the circuit only needs 1 or 2 amps, based on the datasheet the efficiency of the regulator is much lower (60-70 %) around that current consumption. Will my circuit still work if this is the case? How does the efficiency affect the circuit?
for example..
