Power of an ac source
iVenki
Member level 3
Here is the sentence that I read in the book.
For a generator of emf E volts (rms) and internal resistance R, the available power is E^2/4R.
But I thought the power of an ac source =E^2/R.
How did you get that 4 in the denominator?
Thanks in advance.:wink:
Because of the internal resistance R the voltage that is available to be applied to a load resistance R (power matching conditions) is only E/2. Thus: Power=(E/2)^2/R.
You mean there are two resistances with value R?
---------- Post added at 08:24 ---------- Previous post was at 08:22 ----------
Please reply
The maximum power available into a load is when the load resistance equals the source resistance. So, to find the maximum power available into a load resistor you need to consider two resistors in your calculations - the source resistor and the load resistor.
Keith
Reactions: iVenki
    iVenki
