rubixx
Newbie level 2
- Joined
- Nov 24, 2011
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Patagonia, Argentina
- Activity points
- 1,300
OK, well the forum says elementary questions, so should be easy ..
My question is:
If i increase the voltage in my circuit by adding extra batteries in series, and then drop to nominal voltage
with a resistor, will 100% of excess voltage be dissipated by the resistor in form of heat and leave me with the same mAH as when i started?
Given connecting batteries in parallel would be easier in most cases, but in a flashlight tube, for example, when there is 0 tolerance between the cylinder walls and batteries and adding a resistor would be easier.. I cant figure this out!!
My question is:
