power loss in a charger
What kind of battery charger? Different chargers have different losses
what are the factors that causes power loss in a battery charger
Hi ahcraton
You simply asked about power dissipation of a battery charger . but what kind of battery charger ? for what value of power range ? for what kind of application ? these are very important for judgement . because many of the chargers are based on flyback converter or self oscillating flybackc onverter or royer oscillator or transformer coupled damped oscillator .....
Sometimes based on thyristors and IGBTs ! and sometimes based on H bridge . it depends on your application . if you mention them exactly then we can easily judge about dissipation .
Best Wishes
Goldsmith
mainly mobile battery charger and lead acid battery charger also.
if its a switch mode charger then?
Hi ahcraton
Many of the mobile chargers are based on HV oscillators which are without negative feedback and they only produce an AC wave which is HF and then a rectifier and then applying that to the mobile and then mobile will use it's supply IC to make it useable .
some of them are based on self oscillating flyback converter . some of them are based on royer oscillator . and some of them are fully drove flyback converters .
the efficiency depends on the active element which has been used as a switch or as a linear device .
loss will given by : VSwitch*Iswitch *d.c
Best Wishes
Goldsmith
