Power Cable Current?
rhnrgn
Member level 5
Member level 5
hi,
Your cable will carry 200mA OK, but how long is the cable run and what is the working voltage of your cable and the voltage being carried by the cable.?
E
5V and 200ma. 1 or 2 meters long.
How can you calculate?
Reactions: rhnrgn
    rhnrgn
One side is the power loss of the cable that causes heating.
Another point is to calculate voltage drop on the wire.
1.0 mm^2 is good for 10A.
With 10m cable and 10A you get a voltage drop of about 3.6V.
With a 230V system the load sees 226.4V and a linear load sees about 97% of power.
With a 12V system the load sees only 49% of power.
Klaus
Reactions: rhnrgn
    rhnrgn
