Steve Millington
I have come across the ST Microelectronics' STP80PF55 and STB80PF55 P-chanel MOSFETS with an 80A continuous current capability.
I need to control about 150A in the high-side, so I am planning on a few of these im parallel, to form aa rudimetanry solid state, uni-directional relay.
My question is, if these things (in a to220 or D2pak) can handle 80A (obviously with some major thermal relief, how on earth can you integrate them on a PCB. Even if you could keep your copper area as short as possible to your terminal connections, surely you'll need severl ounces of coper substrate to take the current?
Am I right, or is there a better way to PCB mount these. I am not planning to have any other control electronics on the same board as the MOSFETS, and will have m8 terminal studs mounted to the pcb for drain/source connections.
Steve
Steve
