is it possible to load 3D field data to a MWS simulation from another MWS simulation? What I want to do is the following. I want to run a simulation with the device inserted into the simulation domain and another simulation with the device removed from the simulation domain. Then I want to load the field data from the "simulation with device removed" to the simulation where I have the device. And finally, I want to subtruct the fields from each other to obtain the induced fields.
Note: it is possible to subtruct fields within the same simulation by using the template base post proccessing.
Dear irfan1,
please look at the topic ,"how to get a normalized power spectrum for a PCW", Thank you for your consideration, I am very anxious to get a reply.
