Hello guys, I'm currently playing RC servo in position control. But I'm confused, did load affecting position control? Let's said I have a solar panel attached to my servo, when the servo rotate to the desired angle, will solar panel affect the positioning control direct or indirectly?
Unless you've grossly overloaded the motor it should eventually get to right position. It's a closed loop system so the servo is going to do everything it can to get to the desired position
