porting mfrc522 mbed library to keil
dizgah
Member level 5
Member level 5
iran-8par
hi every body
i want to use mfrc522 mbed library in keil compiler & dont want to export codes directrly but i have some problem with these codes
MFRC522.h
class MFRC522 {
public:
  * MFRC522 constructor
  * @param mosi  SPI MOSI pin
  * @param miso  SPI MISO pin
  * @param sclk  SPI SCLK pin
  * @param cs    SPI CS pin
  * @param reset Reset pin
  MFRC522(PinName mosi, PinName miso, PinName sclk, PinName cs, PinName reset);
  * MFRC522 destructor
  ~MFRC522();
private:
  SPI              m_SPI;
  DigitalOut       m_CS;
  DigitalOut       m_RESET;
i know about classes & have some experiences in c++ compiler show errors about unknown type names :pinName, SPI & DigitalOut perhaps <<code>> DigitalOut m_CS;<</code>> defines chip select pin as output & m_RESET is same but whats meaning of <<code>> DigitalOut m_RESET;<</code>> defines chip select pin as output & m_RESET is same but whats meaning of <<code>> DigitalOut m_RESET;<</code>> ? what does it work ? & whats function & type of PinName? what dose it do? whats differences between PinName cs & DigitalOut m_CS;
tnaks every body
