dineshdeshmuk
Full Member level 5
Portable generator is not starting up , problem with bad solenoid also ?
I just shorted the two main terminals of solenoid with screw drive the engine cranks over but the generator is not starting ..... cleaned the spark plug , cleaned the air filter , cleaned all the connections and terminals and lugs ..... checked battery voltage they are 12.65V .....
What might gone bad that stopping the engine from being getting started ?
King Power Gasoline Generator With Mobility Kit , KP3500EKP-I , rated power 2500 Watts , peak power 2800 Watts, 6.5 Hp 4 Cycle , OHV Air Cooled Engine at 220 V ac
Might be the bad spark plug , would change it also but other than what might be the possible cause of the problem ?
If there's a problem with carburetor that is its jammed with dirt or oil ? What's the solution ?
Also without air filter can we start the generator or can run it for longer periods means for 1 hour or for 2 hours continuously without air filter ?
