englishdogg
Full Member level 5
So it was a true unreachable - great
Here is the Scenario of the Problem I am facing.
1.Read a Golden Design and a Revised Design
Map the Points and Compare
2.Read the Same Golden Design and The Different Revised Design.
This time the Revised Design has been created by changing some Constarints in DC
The Problem I am facing is
Some Points in the Golden Design are not reachable for the First Run , But they are NOT_MAPPED for the Second Run
How this can be? because Conformal Says NOT_MAPPED unmapped points are reachable but do not have correspoding point in the Logic Fanin Cone of the Corresponding Design.
So How the same Point in Golden which is reachable becomes unreachable when the revised is changed....
Thank You,
Sachin Shahsikantrao Pampattiwar
you contradict your points 1 and 2
In (1) you mention that they never affect your functionality then in (2) you mention to use -keep_unreach option..
Pls suggest why. to my knowledge and experience these lead to false non-eqs in the design.
