DanTheMan
Member level 5
I'm trying to design a motherboard test board based on a 62 mil FR4 PCB. The device to be tested is a BGA-type PCB which is 40 mil FR4 and which has BGA balls on a non-standard pitch of 2 mm.
Since the pitch of 2 mm is non-standard I cannot seem to find a socket that will accommodate test pins (such as pogo pins) on this pitch. Therefore, I was thinking that short pogo pins could be soldered down on one side to the 62 mil motherboard PCB (probably through carefully sized via holes that match the module 2 mm pitch) and then the module itself could be seated on top of the pogo pins.
Any ideas whether this could work or whether there are any other methods?
Thank you!
Thank you!
