sbit RS at RA0_bit;
sbit RW at RA1_bit;
sbit EN at RA2_bit;
void enable(); // for strobe control
void command(unsigned char cmd_code); // for instruction
void Lcd_string(unsigned char *text); // for writting a string
void Lcd_int(); // for Lcd initialization
void main()
TRISA=0;
TRISB=0;
delay_ms(200);
Lcd_int();
while(1)
Lcd_string("ALMIGHTY *****");
command(0x01); // clear display
command(0x02); // return cursor to origin
delay_ms(200);
void enable()
EN=1;
delay_ms(1);
EN=0;
delay_ms(2);
PORTB=cmd_code;
enable();
void Lcd_int()
RS=0; // for instruction data
RW=0; // for write operation
EN=0; // enable is low
command(0x30); // mode 8 bit, 1 line display,font 5x8
command(0x30);
command(0x0F); // entire display on,cursor on,blinking on
command(0x06); // entry mode is set
RS=1;
RW=0;
while(*text!='\0')
PORTB=*text++; // for outputing a single byte at a time
enable();
