plz correct my system
other-side-of-d-moon
hi guys
can any body correct my system design which is photo parametric amplifier. my teacher confused me and he told me that he want the pump signal at the receiver. so plz help me even by advice coz i already discouraged.
for any suggestions plz tell me why.
can some one help me to get simulation for parametric amplifier please
Your last BPF parameter is : f=181E+12 GHz, that doesn't sound reasonable.
Reactions: mkonca
    mkonca
hi sir i really appreciate ur daily help. can u tell me how much the frequency should be. and if i want to use other band pass filter for the pump signal ( before the power combiner) what is the parameters show i use?
Agere Corp. MDTFF : channel spacing is 100/50/25GHz.
There are different system with different specifications. It has 3 types, baseband over fiber, IF over fiber, and RF over fiber. for baseband over fiber, there are very good IC and schematics, you can search some famous vendor.
The RF modulated on fiber is mmWave, so RF filter you can set center freq as 38G, bandwidth as 2GHz.
i tried ur suggestion but i got bad performance. i got high noise @ the reciver
can any one help me to modify the system??? i want use the pump signal after the photo diode
plz help
