srikanth 123
Newbie level 3
- Joined
- Feb 28, 2013
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,304
-- Company:
-- Engineer:
-- Create Date: 18:04:49 02/15/2013
-- Design Name:
-- Module Name: ram - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
package memory is
type mem_data is array (23 downto 0) of bit_vector(7 downto 0);
end memory;
library IEEE;
use IEEE.STD_LOGIC_arith.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
use work.memory.all;
entity ram is
port(
add_bus:in std_logic_vector(31 downto 0);
data_bus1:in bit_vector(31 downto 0);
data_bus2,data_bus0:out bit_vector(31 downto 0);
mem_ctrl:in bit_vector(2 downto 0);
data_out:out std_logic_vector(31 downto 0);
clk:in std_logic
end ram;
architecture Behavioral of ram is
begin
process(add_bus,data_bus1,mem_ctrl,clk)
variable i1,i2,i3:integer;
variable i:integer ;
variable ram_data:mem_data := (("00000000"),
("00000000"),
("00000000"),
("00000100"),
("00000000"),
("00000000"),
("00000000"),
("01000000"),
("00000000"),
("00000000"),
("00000000"),
("00000010"),
("00000000"),
("00000000"),
("00000000"),
("00000001"),
("00000000"),
("00000000"),
("00000000"),
("10000000"),
("01111110"),
("01100100"),
("01100000"),
("00000000"));
begin
case add_bus is
when "00000000000000000000000000000000" => i:= 0;
when "00000000000000000000000000000001" => i:= 1;
when "00000000000000000000000000000010" => i:= 2;
when "00000000000000000000000000000011" => i:= 3;
when "00000000000000000000000000000100" => i:= 4;
when "00000000000000000000000000000101" => i:= 5;
when "00000000000000000000000000000110" => i:= 6;
when "00000000000000000000000000000111" => i:= 7;
when "00000000000000000000000000001000" => i:= 8;
when "00000000000000000000000000001001" => i:= 9;
when "00000000000000000000000000001010" => i:= 10;
when "00000000000000000000000000001011" => i:= 11;
when "00000000000000000000000000001100" => i:= 12;
when "00000000000000000000000000001101" => i:= 13;
when "00000000000000000000000000001110" => i:= 14;
when "00000000000000000000000000001111" => i:= 15;
when "00000000000000000000000000010000" => i:= 16;
when "00000000000000000000000000010001" => i:= 17;
when "00000000000000000000000000010010" => i:= 18;
when "00000000000000000000000000010011" => i:= 19;
when "00000000000000000000000000010100" => i:= 20;
when "00000000000000000000000000010101" => i:= 21;
when "00000000000000000000000000010110" => i:= 22;
when "00000000000000000000000000010111" => i:= 23;
when others =>
null;
end case;
i1:=i+1;
i2:=i+2;
i3:=i+3;
if(clk'event and clk = '1') then
if(i<= 20) then
if (mem_ctrl(2) = '1') then
--some = := (data_bus1(7 downto 0));
ram_data(i) := (data_bus1(7 downto 0));
ram_data(i1) := (data_bus1(15 downto 8));
--ram_data(i1) := (data_bus1(15 downto 8));
ram_data(i2) := (data_bus1(23 downto 16));
ram_data(i3) := (data_bus1(31 downto 24));
data_out <=to_stdlogicvector(ram_data(i3)&ram_data(i2)&ram_data(i1)&ram_data(i));
-- wait for 0ns;
end if;
if (mem_ctrl(1) = '1') then
--wait for 10ns;
data_bus0 <= (ram_data(i3)&ram_data(i2)&ram_data(i1)&ram_data(i));
--wait for 0ns;
end if;
else
null;
end if;
if(i<23) then
if (mem_ctrl(0) = '1') then
--wait for 20ns;
data_bus2 <= ("000000000000000000000000"&ram_data(i));
--wait for 0ns;
end if;
end if;
if (i >20) then
null;
end if;
end if;
end process;
end Behavioral;
WARNING:Xst:790 - "C:/Xilinx/one/ww.vhd" line 121: Index value(s) does not match array range, simulation mismatch.
WARNING:Xst:790 - "C:/Xilinx/one/ww.vhd" line 125: Index value(s) does not match array range, simulation mismatch.
WARNING:Xst:790 - "C:/Xilinx/one/ww.vhd" line 128: Index value(s) does not match array range, simulation mismatch.
WARNING:Xst:790 - "C:/Xilinx/one/ww.vhd" line 131: Index value(s) does not match array range, simulation mismatch.
