Plotting a phase field and exporting the data
Chungnam12
Newbie
Hi. I'm simulating an antenna design and I'd like to plot the phase distribution on a cutting plane and export the phase data in txt format.
FYI, the cutting plane is tilted, so the plotting plane is not aligned with global coordinate but with local WCS coordinate.
The anticipated results are any of the followings:
1. 2D phase map data on a tilted plotting plane aligned with local coordinate wcs1
2. 1D phase distribution on the cutting plane surface in a polar chart with 2 dependent components - radius and angle
I not only want to plot the distribution but also export the data file in ASCII or txt file.
Thank you
Best regards
Hi!
Try something. Clicking on your reult (e-field):
In Post-proccessing --> Import/Export --> Export --> Plot data ASCII
Regards
LaTeX Commands Quick-Menu:
