Plot gmoverid vs ft in CADENCE specter ic 5.1 with wavescan ( no AWD)
pes68
Junior Member level 3
i wanna plot gmoverid with wavescan ( i do not have this problem with AWD )
in result browser > dc-dc > gmoverid ( or other parameter)
when i open calculator and select gmoverid and then plot with calculator , select x-axis in waveform and then axis > edit its not open why ?
So when I plot gmoverid in terms of ft(gm/2pi*cgs) such that ft can be calculated by the calculator to plot
I can not change my x-axis in terms of ft and gmoverid vs ft is plotted
Each parameter calculator to plot the x-axis, it can not be changed
I think you have to run ac analysis to get frequency as x-axis.
