Please let me know if this is feasible using digital pots...also what would the expected accuracy be.
I know the 7107 is used in digital voltmeters, and they are quite accurate is it possible to achieve similar accuracies if I make my my own voltmeter using the 7107 ??
I am sorry if the above description is sketchy as the idea is still in my head and I have not made any prototypes yet to get accurate information.
So instead of fixed resistances I will use the auto-range circuit instead so no selection of resistances would be required.
Is there any way of increasing the resolution of the circuit, it is at present 0.1 mV, ie: values will be displayed as 12.1, 12.2 etc. I want to display 12.123 instead would this possible ??
you can always do that,
like in arduino you can use
Serial.print(variable,7);
it will gives you 7 decimal places,so in your case 12.123 it would be 3
and you have to make sure the datatype is right for your value,use float number for the safe-way
