Aug 28, 2011 #1 A arbj Full Member level 4 Joined Oct 5, 2008 Messages 238 Helped 31 Reputation 62 Reaction score 20 Trophy points 1,298 Activity points 2,599 Hi, I am looking for a temperature sensor that can measure upto 400 degc (min=10 to 20 degC) It will be ideal if the sensor can be directly connected to an ADC or a PIC. I would like to avoid amplifiers as much as possible. please help. thanks a
Aug 28, 2011 #2 bigdogguru Administrator Joined Mar 12, 2010 Messages 9,821 Helped 2,350 Reputation 4,694 Reaction score 2,272 Trophy points 1,413 Location Southwest, USA Activity points 62,383 There are several options, here is one: Oakton WD-08439-64 Low-Cost General-Purpose Thermocouple Probe, Type T, Temperature range: -418 to 752°F (-250 to 400°C) Depending you the environment of the Thermocouple they can get quite expensive. BigDog
Aug 28, 2011 #3 A arbj Full Member level 4 Joined Oct 5, 2008 Messages 238 Helped 31 Reputation 62 Reaction score 20 Trophy points 1,298 Activity points 2,599 I found AD594, https://www.sparkfun.com/datasheets/IC/AD595.pdf but this needs a type K thermocouple. Could you please suggest a suitable thermocouple for this device.
Aug 28, 2011 #4 bigdogguru Administrator Joined Mar 12, 2010 Messages 9,821 Helped 2,350 Reputation 4,694 Reaction score 2,272 Trophy points 1,413 Location Southwest, USA Activity points 62,383 How about this one: Temperature range: –418 to 1650°F (–250 to 899°C) Oakton WD-08439-62 Low-Cost General-Purpose Thermocouple Probe, Type K BigDog
