Please, is anyone very familiar with hspice? Specifically, how to combine .ms(mt)# file in hspice
CY.Lim
Newbie level 5
Newbie level 5
plz. anyone very familiar with hspice? how to combine .ms(mt)# file in hspice
hi all.
i'm sorry. i don't write english good well.
I wanna measure threshold voltage and saturation current of mosfet in hspice using measure command.
After simulation, I get ms0~4 file which is coner simulation result, tt ff ss fs sf.
I want to see one file. how to combine .ms# file?
Could you give me some advices!thank!
Re: plz. anyone very familiar with hspice? how to combine .ms(mt)# file in hspice
In UNIX or LINUX:
cat fileName.ms[0-4] > fileName.ms
Reactions: CY.Lim
    CY.Lim
Thank you for your help.
I have 1 question.
I enter command which cat LV_nMOS_vth.ms[0-4] > LV_nMOS_vth.ms in terminal.
I write command which cat fileName.ms[0-4] > fileName.ms in terminal in hspice.
so, I get file.ms
I want to get file after simulation right away.
How to write .sp file in hspice.
I write command which cat fileName.ms[0-4] > fileName.ms in terminal in hspice. so, I get file.ms
Isn't that good enough?
Use the Data-Driven or the Parameter Sweep method: View attachment HSPICE_User_Guide_Simulation_and_Analysis_Version_E-2010.12_December_2010_p459-460.pdf.
Reactions: CY.Lim
    CY.Lim
Thanks. erikl.
I'm sorry. I don't understand your advice.
Perhaps, I didn't enlighten you about my question.
But, your advice is very helpful.
So, I find another method. This is not 'cat' command.
I use '*.perl ' command. It is difficult to use but very effective.
