I need a driver for PIC to connect it with USB to my project that depends on USB interface. Can you help me to make that interface btween PIC and USB??!
Do you need a true USB interface, or would a COM-port based USB interface do. The FTDI chips are convenient usb-to-serial convertors. True USB requires a relatively steep learning curve, especially on the host driver side.
Hi. You can use PIC witrh USB built-inIC18F4550(2455, 2550, 4455), or You can use external usb like from SL811H cypress(https://www.cypress.com/portal/serv...CommunityID=209&PageID=259&fid=10&rpn=SL811HS) it is host or client USB 12Mbps(master or slave configurable).
If you use PIC with usb microship offer PC drivers, CCS also have examples.
